T
Tel boy
Turning an ordinary 12-volt car battery charger in to a regulated
charger?
I was just wondering if any electronics whiz kid out there could tell
me if this is possible, or if indeed this is what I require.
I have a 6amp 12-volt battery charger for charging my car battery, no
problems here!
However I also have a motorcycle that has one of those sealed
batterys, now from what I have read I believe that you are not
supposed to charge this type of battery with a normal charger, as it
will damage the battery somehow.
Is this correct?
Would it be possible to build a small circuit that I could put in line
if I wanted to use this charger to charge the motorcycle battery
without causing any damage to it? or am I barking up the wrong tree?
Thanks for any help.
charger?
problems here!
Is this correct?
