Trying to Find the Right Proximity Sensor
rlvmaiden
May 25, 2012
May 25, 2012
Hi, I've been trying to find a distance sensor with certain specifics for the last few days and haven't quite been able to find what I'm looking for.
I need the distance sensor to either be ultrasonic or inductive; it's going to be measuring the distance of a steel beam so either of these would work.
It also needs to have a fairly high resolution, no lower than 2mm.
It's going to be used in an outside environment so it needs to be able to function in as low as -40 degrees celsius.
The sensor range needs to be fairly short; minimum range no greater than 4mm, maximum range no lower than 40mm.
The sensor also needs to have an analog voltage output, or something similar that can be wired to a PLC to read the distance at all times.
If anybody knows where I could find a sensor with these specifics, I'd greatly appreciate any info shared.
Thanks.
gcb
Mar 26, 2012
32
Mar 26, 2012
32
maybe saying the specific problem would help to get suggestions of other ways to tackle the problem
shrtrnd
Jan 15, 2010
3,876
Jan 15, 2010
3,876
-40 degrees celsius is -40 degrees farenhiet.
Where are you at, Antarctica?
