Tri-level composite signal from microcontroller
epicedium
Jun 29, 2017
3
Jun 29, 2017
3
What is the easiest way to generate this pulse from a microcontroller running at 3v3? I have IO pins and PWMs available.
https://en.wikipedia.org/wiki/Tri-level_sync
I haven't dealt with negative voltages before, and I'm not that familiar with analogue electronics (other than simple opamp circuits). My first instinct is to generate -3v3 (somehow?) then use 2 or 3 microcontroller pins to switch 2/3 mosfets or transistors with resistors dividing voltage, but I do wonder if there's a better/ simpler way.
It doesn't seem possible/appropriate to create a virtual ground unfortunately, as the composite signals go out over BNC using chassis ground.
duke37
Jan 9, 2011
5,364
Jan 9, 2011
5,364
The wikipedia article says there is no DC, perhaps a capacitor in the line would be sufficient.
There are integrated circuits which can give a low current negative supply, I have never used one.
Alec_t
Jul 7, 2015
3,591
Jul 7, 2015
3,591
The opamp would need a dual-polarity supply if you want it to put out a negative-going pulse.
Alec_t
Jul 7, 2015
3,591
Jul 7, 2015
3,591
Duke suggested a cap. Here's a sim. Good enough for your needs?
epicedium
Jun 29, 2017
3
Jun 29, 2017
3
Alec_t, Duke- the cap, it may well be acceptable, yes! I'll simulate it into a 75Ohm load and experiment- my experience with AC is pretty minimal so I don't really grasp how it works. I assume that I could clamp the spike with diodes and that the magnitude and duration of the spike are a product of the capacitance and load. I'll report back once I've had a play around. Thanks!
