transistor sizing and dynamic current for cmos inverter
I'm trying to understand how to determine transistor geometrys for a
CMOS inverter ie. operating as a switch.
For example, the cmos inverter shown here:
http://www.flickr.com/photos/tedthornton/317785664/
I'm not sure what the (W/L) ratio of my transistors should be.
From my understanding, when Vin switches from 0v to Vdd (3.3V), the
PMOS will switch off and the NMOS will switch on. For the output to
change voltage from 3.3V to 0V, Cload needs to be discharged through
the NMOS device. So if Cload is 2pf at 3.3V (Q=CV, so 6.6e-12 Coloumbs)
and I want it to discharge in 2ns then the current flow through the
NMOS will be 3.3mA (I=Q/t).
As the NMOS Vds is initially 3.3V (before the capacitor discharges),
and the Vgs is 3.3V (as the input has switched, but not yet the
output), then the transistor is operating in saturation initially
(Vds>Vgs-Vt), so I should use device sizes of (W/L) =
2*Id/(K'(Vgs-Vt)^2). But very quickly, the transistor will be operating
in the linear region as the capacitor discharges, so Vds drops (so Vds
< Vgs-Vt). Then I recalculate (W/L) using the equation for the linear
region of operation, and choose the larger (W/L) value of the two.
But in reality, the NMOS begins switching before 3.3V, at around 0.7V,
so at that point the Vgs is much lower which affects the saturation
equation (ie. calling for a much larger W/L ratio for the NMOS device).
Should I then choose W/L values based on the worst case, when the
transistor starts switching at 0.7V (so the minimum Vgs value), in
order to meet my 2ns switching time? Or do I calculate W/L based on
when the maximum current is drawn (when both NMOS and PMOS are on, I
believe, although I'm not sure what this maximum current is - 3.3mA?)?
I'm very confused.
If anyone can help clear up how I go about sizing transistors for
dynamic switching operation (specifically, how I determine the maximum
drain current, and what mode the transistor is operating in so that I
know which equation to use to calculate (W/L)), I'd be very happy!
Cheers,
Ted
