Transistor pair to switch between Voltages
Discussion in 'General Electronics Discussion' started by fatman57, Nov 13, 2016.
  1. fatman57
    fatman57
    May 27, 2013
    101
    Cheers Steve! Much obliged...
    fatman57, Dec 24, 2016
    #21
    1. Advertisements
  2. fatman57
    fatman57
    May 27, 2013
    101
    Please find final version below. Many thanks for all your help to date!!!!
    [​IMG]
    fatman57, Jan 5, 2017
    #22
    1. Advertisements
  3. fatman57
    24,098
    2,341
    All good except you have drain and source sealed on your MOSFETs.
    The LEDs will probably be very dim.
    (*steve*), Jan 5, 2017
    #23
  4. fatman57
    fatman57
    May 27, 2013
    101
    Thanks Steve,
    Sorry, but what do you mean by sealed? I used an online sketch service and it was what came out of the box if you are referring to the symbols.
    Will the LEDs be dim because of the values of the resistors?
    Much obliged
    #24
  5. fatman57
    24,098
    2,341
    AAAAGH "swapped". Bloody autocorrect.
    Yeah 10k for the LEDs is a bit high. The one on the 5V input need to be about 1/3 of the value of the one indicating 12V if you want equal brightness.
    #25
  6. fatman57
    fatman57
    May 27, 2013
    101
    Again! I followed the same example as seen on post #19 - makes me feel a little embarrassed - not sounding too stupid what indicators should I look for to make sure I get it right (as in with regards to schematic diagrams)?
    Thanks! I will use an online calculator to assist in those values.
    fatman57, Jan 6, 2017
    #26
  7. fatman57
    24,098
    2,341
    I find that drawing in the body diode on MOSFETs helps a great deal in getting them around the right way. Then, knowing that in simple switching applications the source is connected to the same supply rail as the channel type, you'll get everything the right way around.
    (*steve*), Jan 6, 2017
    #27
  8. fatman57
    fatman57
    May 27, 2013
    101
    OK thanks, I thought I had made it the same as post #19, does this picture correctly illustrate what you are saying:
    [​IMG]
    #28
  9. fatman57
    24,098
    2,341
    Yeah, although typically you'd draw the p channel one up the other way.
    #29
  10. fatman57
    fatman57
    May 27, 2013
    101
    Please see my hopefully final version below:
    [​IMG]
    fatman57, Jan 12, 2017
    #30
  11. fatman57
    24,098
    2,341
    Looks fine.
    Note that they are P Channel MOSFETs, not PNP MOSFETs.
    We've also spoken about the resistors for the LEDs.
    Neither of the issues will stop it working :)
    (*steve*), Jan 12, 2017
    #31
  12. fatman57
    fatman57
    May 27, 2013
    101
    Yes thanks Steve I just wanted to check it was the right way round. I have a circuit board prototype almost ready will post a picture if anyone is interested. Comments welcome.
    fatman57, Jan 13, 2017
    #32
    1. Advertisements
