K
Ken
I am not an electrical engineer and am trying to figure out what
voltage to put on a Motorola mobile speaker squelch lead. My research
has taken me to the [low] limit of my comprehension.
The lead ultimately reaches the base of a transistor amplifier set up
as a "common emitter." The collector is connected to a number of
sub-circuits that apparently effect the squelch function. There is a
table on the schematic that states the following for the subject
amplifier:
unsquelched: base=0.6, collector= 0.4
squelched: base=0.0, collector= 7.5
I take this to mean that a voltage of .6 volts at the base will open
the squelch and a voltage of zero will close the squelch.
My most convenient voltage source is readily adjustable from 0 to 1.2
volts at the base.
(1) Will it harm a transistor amplifier if 1.2 volts is applied to the
base?
(2) What will happen to the collector voltage if the base voltage is
1.2V?
(3) Is it important that I change my source so that the voltage at the
base will never exceed 0.6V?
Ken C
Ken
(to reply via email
remove "zz" from address)
amplifier:
volts at the base.
base?
1.2V?
Ken C
Ken
(to reply via email
