Toshiba satellite laptop problems
phlox
May 19, 2012
77
May 19, 2012
77
Hey all..hope all is well.
Ive got a problem with a toshiba laptop.
Problem is that it wont turn on if ac adaptor is connected. Thr lights do turn on though and it charges.
It does turn on sometimes only on battery.
When it does turn on it makes a sqeauling noise on the motherboard..sounds near the cpu or northbridge.
When i does turn on it turns off when booting windows.
What component could be the issue?
pharaon
Oct 28, 2014
439
Oct 28, 2014
439
could be hard disk failure because of bad sector on it
phlox
May 19, 2012
77
May 19, 2012
77
Its not a hard disk issue as it switches off even without hdd attached.
Its not overheating as well as ive removed motherboard and cleaned cpu heatsink and fan and put on new thermal paste
Bluejets
Oct 5, 2014
6,901
Oct 5, 2014
6,901
Battery not charging even though the task bar indicator might say it is.
phlox
May 19, 2012
77
May 19, 2012
77
Battery does charge...the laptop only runs iff battery..when charger attached it switches on but has no display...when running off battery it runs fine
pharaon
Oct 28, 2014
439
Oct 28, 2014
439
try to dispatch battery and run the laptop of the dc oly
tedstruk
Jan 7, 2012
476
Jan 7, 2012
476
I had a satellite that did this, and I found a bad wire in the Power supply cord. Still works fine today.
