B
bharat
Does anyone have datasheets for this IC?
On my Toshiba 61A61 RPTV, nothing was coming out of 1222 IC and there
was no audio or video. So I replaced the IC. When I powered the TV
on, I heard a crackle (not too loud but enough to tell me something
happened). Upon checking, I found that audio was working fine but
video was still out. Further checking revealed that pin #22 (it is
labelled as 9V(DEF) on schematic) is internally shorted to the ground.
When I disconnect the pin from the board, I see 9V on the node as it
should. Because that pin is shorted to ground inside the IC, can't do
much but to replace it again.
what is causing this? I ordered another IC but am afraid to install
it as same thing may happen again....Everything else looks good. All
voltages coming out of power board are what they should be (except all
voltage associated with H.out).
Thanks for any help with this one.
