R
Richard Rasker
Hello,
I regularly design relatively simple stuff with PIC and Atmel controllers
and the likes, and when I need to interface with the outside world by means
of switches or other slow interfaces, I simply use a series resistor
between 100R and 1K, followed by a capacitor to ground, value between 1nF
and 100nF (depending whether it's a scanning matrix or not, and the desired
speed).
Now I ran into a bit of a dispute with another designer who says that this
is a totally wrong approach, and that using those 3-terminal chokes instead
of series resistors and ground capacitors is far better (also when driving
any significant current).
Indeed I often see 2- or 3-terminal chokes in series with supply and I/O
lines of existing digital stuff, but even more often, they're nowhere to be
seen.
My question: what advantage has a microhenry (or even less) choke compared
to a well-defined RC filter? I understand the need to prevent HF from both
entering and leaving the circuitry, and compliance with EMC regulations is
very important, but do those little chokes actually do a better job in this
respect than simple RC?
Thanks for any leads,
Best regards,
Richard Rasker
speed).
seen.
Best regards,
Richard Rasker
