Hie there I made a tl 494 circuit which I designed to oscilate at 40KHz with emitter follower outputs. the problem is a dc component appearing on the outputs superimposed on the square wave. The internal BJTs are Ok as I confirmed with a multimeter and if I apply a sufficient voltage on the deadtime control, the bjts are completely off showing that they are ok. my problem is this steady dc components on the outputs. How do I remove it.
Categories
Platforms
Content
