N
N_Cook
I discovered this via needing to isolate Vcc of a SOIC where the trace
is under the IC and a multilayer board.
I have a reel of 0.08mm diameter tungsten wire , tungsten probably not
critical and diameter only needs to be small enough to go under SOIC pins.
I've since tried, pin by pin, of an 8p SOIC on a scrap board with a
success rate of 8 out of 8 isolating each pin , first time. Leaded
solder, PbF situation not tried yet
Feed length of the wire under a pin , long enough to grab hold of both
ends. Pull outwards and slightly upward while quick soldering iron melt
of the pin solder. The wire pulls through, but surprisingly , 8 out out
8 times so far, the solder has not rejoined across the gap. Then a
sliver of mica under the pin , in my Vcc situation, to fully
isolate for testing purposes.
But of course where hot air is out of the question , the IC is required
for salvaged re-use etc, this method pin by pin could be used even in
restricted space,
to salvage a whole SMD IC. I wonder if a single loop per side of a DIL
or quad footprint IC , and progressive single pin melting , would work
with 8 or more pins in one operation - worth trying some time
restricted space,
