The step by step design procedure for AN4134
R
Richard
http://www.fairchildsemi.com/an/AN/AN-4134.pdf
http://www.fairchildsemi.com/collateral/AN-4134.xls
The xls file is to be used with the design steps in the pdf file.
In the pdf file, I'm getting stuck at : Step (3) (b) RCD reset
In Excel: You need to choose the Excel sheet "Forward with RCD reset": I
have a probblem with cell C30. I don't know how to get to a value to put
into cell C30, nor do I know what the parameter is. Cell F30 surely is the
nominal snubber capacitor voltage, that is, the voltage across the snubber
capacitor. So, what is the parameter that goes in cell C30 and how do you
determine it's value? TIA.
John Popelish
Second try:
You get to pick any voltage you like, as long as it is greater than
the value in F30. Higher voltage minimizes the time wasted to reset
the core, while stressing the switch and rectifiers with higher
voltage.
I am working on understanding this statement from page 3 of the pdf:
"winding and reset winding, respectively.
Since the snubber capacitor voltage is fixed and almost
independent of the input voltage, the MOSFET voltage
stress can be reduced compared to the reset winding
approach when the converter is operated with a wide input
voltage range."
The snubber voltage is a function of the average magnetization current
times the snubber resistor value. The resistor value is constant. If
the transformer were perfect, and the output voltage was perfectly
regulated and there were no resistive drops related to various load
currents, then the duty cycle is inverse to line voltage, so as the
voltage gets higher the percent of on time goes down. The
magnetization current thus climbs faster, but has less time to climb,
so it reaches about the same value, independent of line voltage.
I am looking at the voltage and current waveforms on page 3 and so
far, it all makes sense. The magnetization current rises while the
switch is on (and output current is being sent through the output
rectifier), and decays while the current must push up to snubber
voltage. But then, the current, Isn, reaches zero, and the inductor
no longer pushes current into the snubber cap through the diode and
the winding voltage falls toward zero. At this point (t3 to t4) the
graph shows the magnetization current decreasing below zero much
faster than it fell while Isn was flowing. A faster rate of change
implies a larger winding voltage, but the voltage waveform, in red,
shows a decreasing voltage heading toward zero as the transformer
waits for the next on pulse.
So I don't understand where the expression Vsn/(Lm/Coss) comes from
that I think is describing the value of voltage being applied ot the
winding while waiting for the next pulse t4 to t5). I have no idea
what Coss is. My guess is that this is the value of magnetization
that develops as the winding capacitance charges from Vsn down to just
below zero, where the output rectifier comes on an shorts the
secondary, allowing that value of accumulated magnetization current to
circulate with little change till the next on time occurs.
So to get back to the approximately fixed Vsn, I guess the on time is
inverse to line voltage, so the peak snubber current is fixed, and the
energy dumped into the snubber is fixed per cycle, regardless of line
voltage and is almost fixed independent of load current, so as long as
the cycle time is fixed, there is a constant average flow of energy
through the snubber resistor, so a fixed average voltage. And the
snubber capacitor keeps the instantaneous voltage near the average.
So back to the spread sheet, you get to pick any value for the snubber
nominal voltage (that will stay pretty close to that by the above
reasoning) as long as it is greater than the specified minimum value
if F30. The higher voltage you choose, the higher the stresses on the
switch and rectifiers, but the more of the cycle time the transformer
is able to transform power to the secondary (the higher the
transformer utilization). If you pick a generous core size for the
transformer, this is not much of a concern, so you can treat your
switch and rectifiers better by picking a lower voltage.
R
Richard
John Popelish said:
Second try:
voltage.
I'm still not getting it.
This is what I am seeing:
So far in the steps, the set input parameters (in blue) I've addressed are:
maximum line voltage; minimum line voltage; line frequency; output volts and
amps; estimated efficiency; dc link capacitor; maximum duty ratio. I
understand these parameters, that is, what they are. But I don't understand
what the nominal snubber capacity voltage is. There are two voltages
associated with row 30, the one in blue and the one in red. I'm looking at
the red one and saying, given all the parameters in blue that are
pertaining, the voltage in red is a voltage that will be present across the
snubber capacitor and is 150.6 volts. Okay, but what is the voltage in blue?
It's not the voltage ascross the snubber, that's in red. This is what I'm
thinking. I'm wondering if things are confusing me because of course these
calculations are not with a fixed input votage, a range is specified. I
could not reconcile the values in C24, C25, and C26 until that dawned on me.
John Popelish
The blue one is a voltage of your choice, as long as it is higher than
the one in red. Lower values stress your power switch and rectifiers
less, but will force a bigger transformer size. The value in there to
start with is the program's suggestion.
I'm looking at
The red one is a limiting value. Note the > symbol between the blue
entry box and the red limit box, implying that your entry must be
greater than the limit.
R
Richard
Okay. But what is the nature of the my choice?
For instance, I have the choice to set what the minimum input voltage can be
and what the maximim input voltage can be. I know that here I'm setting the
potential ac input parameters. Of course these settings are not what
actually you would measure in the circuit unless the ac input was at either
max or min. I'm not strictly setting what the ac input voltage will be in
the circuit
But I don't understand what it is that I'm setting at C30. AlI know is that
it has to be higher than F30. To my mind F30 is Vsn or would be the voltage
across the snubber if you were to measure it. If I was setting F30, by being
able to place choice of value there, then I'd be setting what Vsn would be
in the circuit by direct entry of a value. Anyway, is C30 a choice
something similar in nature to the choice of either max or min input
voltage? And if it is, what is the parameter exactly?
R
Richard
Actually, one could argue that this is not important. The important point is
what you make "Maximum nominal MOSFET voltage =" by ones choice of value in
C30.I ought to move on I guess.:c)
John Popelish
the circuit
No. the circuit will be designed for you to produce approximately the
value of Vsn that you specify in C30. If you want to keep the Mosfet
and rectifier voltage stresses at their absolute minimum, choose the
same value as is in F30. But this will cause the program to specify
more core area, possibly pushing the choice up to a bigger core size.
Try a few values and see what changes in the design, especially
voltage rating for the mosfet and rectifiers, and the transformer
size. This parameter gives you some choices with different trade
offs. It is a degree of freedom in the design.
Of course, it directly changes the value of the snubber resistor,
since the voltage drop across that resistor (averaged by the snubber
capacitor), as the core resets through it, is what produces the
snubber voltage.
R
Richard
snubber voltage.
Okay, I understand now. F30 is a calculation to be used as a guide, the
value placed in C30 is Vsn, and you have the choice of determining this.
IOW, if the figure you place in C30 is 300v and if you were to measure Vsn
in the circuit, it would be around the 300v mark, not the value as shown in
F30. In any event you must choose a value above the F30 value.
Thanks.
I'll now proceed further in the steps. Don't be suprrised if I get stuck
again and ask for more help. If so I will post agaijn on this thread. Rich.
R
Richard
I dropped sci.electronics design because the group I think is for
professional designer enquiries.
However in response to a query on this issue, "RL" in sci.electronics
design wrote:
"Although C30 is an input in the spreadsheet, it has no effect except
to make the statement " [C30] > [F30] " true or false.
If the statement is false then the voltage snubber capacitor is not
being used as the mfr intended, and may fail.
F30 is the average voltage across the capacitor. This is a function of
the sum of the known magnetizing energy and leakage inductance energy
developed at the selected conversion frequency, developing a total
energy burn-off requirement in the clamp's bleeder resistor.
As the C value reduces in this dissipating clamp, AC ripple and DC
peak voltage across it will increase, requiring larger margin between
the ratio of C30 and F30 spreadsheet values, as the part must be rated
for the peak voltage value (~ and the dVdT ~ another topic).
As the R value increases, the average voltage required to burn off the
known leakage and magnetizing energy will also increase above the
calculated volt-second reset 'minimum' voltage provided in the
spreadsheet.
RL"
I might be able to get something from this so I've attached it to this
thread.
R
Richard
Step 5.
Determine the proper core. Well, that seems to consist in setting "Maximum
flux density swing" (C50) between 0.2 and 0.3T and then reading off
"Estimated AP value of core =" (C51). I've no idea what C51 is and how to
use it in selecting a core (unless you don't use this figure in any kind of
core selection from a manufacturers range). It looks like value is given in
mm4. I notice in:
http://www.tdk.co.jp/tefe02/e140.pdf
that there are columns thus:
C1 Ae le Ve
(mm-1) (mm2) (mm) (mm3)
but no mm4.
I'm stuck again! if C51 is tge determination of the proper core, then I
don't know what to do with it. I thought it was something that I used so I
could select a manufacturers core product.
R
Richard
Richard said:
Step 5.
mm4. I notice in:
C1 Ae le Ve
but no mm4.
If step 5 is about actually choosing a core from a manufacturers range, then
the best I can do is this:
Ap = Aw * Ae
In TDK's catalogue I'm given Ae and I suppose I can calculate Aw from the
dimensions (A - I). I'll try that tomorrow.
R
Richard
Ap = Aw * Ae
I've probably cracked it.
If we look at page 10 of the pfd file, at step 5 we find that there is a
core selection, the core is EER2834.
But how was that chosen. Well, if we look at the estimated AP value of core
(I'm not sure what AP is, but never mind) it's 9275 mm4. Ae is cross
sectional area of core which we can input as a value. Here it's 86 mm2. AP =
Ae * Aw. Well if we take AP to be 9275 mm4 we work Aw out to be 107 mm2.
But for some reason, probably the because it's the nearest value in the
product offering, an AP value of of 12470 is declared. At any rate we have
145 mm2 for Aw. (86 * 145 + 12470).
In actual fact, what probably happenned is that we know Ae is 86 mm2. 86
mm2 might have been chosen because 86 mm2 is a common cross sectional area
for cores.Then we looked through a manufacturers list of products looking
where Ae is 86 mm2. Well, we know that Aw ought to be 107 mm2 or higher. We
find the nearest core to be Aw of 145 mm2, so we choose that. That gives AP
of 12470 mm4, but that's okay because it's higher than the estimate of 9725
mm4.
So let's try this for real with the TDK catalogue:
I beleive I have some choices the E series cores (EI, EE, EF) or ETD and EC
cores.
EI cores: The material is P40. On page 20 we see PC40E128 -Z That has an Ae
of 86 mm2. But is Aw 107 mm2 or higher? What is Aw? Aw= F * (A -(D+ 2H))
Aw = 12.25 * (28 - (7.2 + 2 * 4.5)) = 72.275mm2
This is too small because Aw is lower than 107 mm2. AP is only 86 mm2 *
72.275 mm2 = 6215.65 mm4.
Well it looks like the smallest EI core that will do is PC40E135-Z, this has
Ae of 101 mm2.
Aw = 18.25 * (35 - (10 + 2 * 5)) = 136 mm2
This would make AP 101mm2 * 136 mm2 = 13736 mm4. Higher than the estimated
9275 mm4.
One could repeat a similar process for the other core choices, ETD and EC
cores.
I hope my calculations are correct especially regarding working out of Aw
from core dimensions given inthe TDK catalogue.
You would think the process ought to be easier, but I cannot see a simpler
way
R
Richard
Ae of 86 mm2. But is Aw 107 mm2 or higher? What is Aw? Aw= F * (A -(D+ 2H))
That divide by 2 ought to be under the (A-(D+2H)) bit.
R
Richard
Richard said:
Aw values are quoted in the bobbins sections. I wonder if that's where I
should seek Aw rather than calculation form the core data dimensions.
Okay:
AP stands for Area Product and is given as mm4. Because I surmise it's the
product of two areas: Area window (Aw) and area core (Ae).
AP is what we have got to get right. You chose a core that has an AP above
the estimated AP core value.Then you take whatever Ae is from the catalogue
and put that in as the cross sectional area of core (C52).
Fine, but you have got to chose the core.
Well, there could be a lot of things involved, but concerning AP, it's a
matter of ensuring Aw *Ae = AP or higher.
It seems to me that with the TDK catalogue Aw is to be taken from the
bobbins data sections.
Looking at the EI cores (I hope these cores are okay for the job) we see the
following:
Product Ae Aw AP Bobbin
PC40EI28-Z 86.0 39.4 3388.4 BE28-1110CPLFR
PC40EI30-Z 111 44.5 4939.5 BE30-1110CPFR
43.2 4795.2 BE30-1112CPFR
47.6 5283.6 BE-30-5112
PC40EI33/29/13-Z 119 88.8 10567.2 BE33-1112CPLFR
PC4040EI33-z 101 88.7 8958.7 BE35-1112CPLFR
PC40EI40-Z 148 108 15984 BE40-1112CPFR
108.1 15998.8 BE401112CPNFR
110 16280 BE-40-5112
The estimated AP value of core is 9275, therefore suitable cores are in the
EI range at least are:
If I chose PC40EI33/29/13-Z I'd put in 88.8 for Ae (Cross sectional area of
core) (Ae))
If I'm making a mistake by taking Aw from the bobbins sections, then a lot
of the above is nonsense.
John Popelish
spreadsheet.
RL"
thread.
I haven't waded into the design spread sheet to see what affects what,
so I have no opinion on this post.
John Popelish
Yes, Aw is the winding window area (copper total cross section).
John Popelish
Richard said:
Okay:
following:
core) (Ae))
I think you are correct. The general size factor for a transformer
involves both core cross sectional area and copper winding window
area.
