You get what you pay for. Space qualified hardware has to withstand an
extreme mechanical stress environment during launch, a period in cold
hard vacuum and then still work afterwards.
Several people have come up with plans to send humans. You could do it
provided you don't want to bring them back safely again, and are
prepared to accept the risk that they get fried by a solar flare on the
way. If it was done today it would be more as a variant of "Big Brother"
style edutainment rather than for the science. The long period of
weightlessness leaves you with astronauts who have to be stretchered out
of the landing vehicle. It won't be quite so bad on Mars but it is
unlikely that the intrepid travellers could do much when they arrived.
OTOH robots provided they get a soft landing at the end are able to
survive with minimal creature comforts on the journey. Unfortunnately
Mars has a reputation for hard landings. Including the one caused by
Imperial vs metric units mixups.
Parts of faster better cheaper are right on the nail. There is no point
at all in using massive resources to build something that is already
obsolete by the time it launches. The delays on the HST launch meant
that the cameras on it had been surpassed by newer ground based CCD kit
before the thing even flew.
It also depends whether you can find useful things to do for 10 years.
Having a reliable framework that you can hang different experiments onto
and send them off to test at different locations has merit.
Now about 'faster', well it is not faster either, hey why not send a
miniature ANT
(nano tech should make that possible;e), and then claim you travelled
1 meter in 2 years?
What should have been, it seems, is a couple of big rovers, with
normal big rubber? wheels,
like the moon buggies for example, so _later_ (unfortunately) astron[a]
uts could use these to get around.
The weight factor makes interplanetary travel expensive.
They certainly lost their best rocket designer. Nothing after his era
comes close to the majesty of the Saturn V booster.
Where do you get that idea from. Several of the planned experiments in
play and planned are specifically to look for signs of life using
isotopically marked likely redox food species.
The Viking landers results were at best ambiguous and most likely the
results of peroxides and perchlorates in the Martian soil. The latter
pose the interesting possibility of liquid water existing at low
temperatures and pressures in the Martian subsoil. It isn't clear if any
organic life as we know it could exist in an oxidising environment.
And not even any good for science. Most of the stuff done on it would
not score well at a high school science fair.
They are working on it and may have a solution. Robotic space
exploration is the way forward unless and until we run into something
that is too tricky for our robotics to handle. Humans are just too
fragile and clumsy in space when compared to machines.
Well I agree with some of your post and some of it I do not agree
with.
I am very aware of the engineering that went into the Mars rovers and
the support that operates them.
Very impressive.
They do represent a goal for other missions to shoot for.
The Mars probes are a good example of how to do space exploration. I
would like to see more probes go to the moons of Jupiter and Saturn
where there are environments that may harbour liquid water and the
various chemicals that we think are needed for life to get started.
Regards,
Martin Brown
