the prettyLow Drain Flasher circuit with BJT
baba101
Nov 15, 2017
4
Nov 15, 2017
4
Here I present a very low drain circuit .
This is led flasher at .7sec delay ... takes .89mA
Please confirm if my measurement is correct .
Feature :
works from .7V also
just two value resistor cover wide vcc
for .7 - 3v keep Rx 220E
and for 5-16V Rx is 47k
73's de Edd
Aug 21, 2015
3,628
Aug 21, 2015
3,628
Explain how the "LEAKY" 47 ufd electrolytic, being inserted into the power supply input line, to feed the circuitry, fits into the grand scheme of the units design plan ?
baba101
Nov 15, 2017
4
Nov 15, 2017
4
great catch.. that one helps it to start Off, else needs a dab of voltage to make it , probably a diode in series will help cut the leak ?
Audioguru
Sep 24, 2016
3,656
Sep 24, 2016
3,656
Can't you see that the polarity of the 47uF capacitor is backwards?
