Can somebody lower the high level explanation of the 555 Timer IC in a light sensitive trigger
Heres the text,
Contrary to the normal use as an astable multivibrator, the 555 IC in this circuit functions as a comparator. To explain this rather unusual application,it is necessary to note the operations in the 555 IC - The output goes high upon the receipt of a trigger pulse at input pin 2. This pulse is of the voltage which is 1/3rd of the supply voltage.The output goes low again when the voltage at the second input pin 6 becomes 2/3rds of the supply. In the present design the second input is not used but the output of the chip can none the less revert the low state, since pin 6 is directly connected to the positive rail."
Heres the text,
