OldSchool said:
They all work but sound like crap. If I just run my Kenwood amp and
tuner through the system (without any link to the yama) it sounds fine.
Sounds like my 25+ year old amp finally boosted it's last signal.
Are you saying that all of the other inputs BAR the " Aux " work ok when
driven by the Yammy, but sound poor ? That is an odd state of affairs,
indeed. Whilst it will sound crap if you run a line level output from the
Yammy into the Kenwood's phono inputs, due to the fact that a line level
signal is about 100 times what the phono input is expecting, the other
inputs should work just fine. Tuner, CD, Tape In, and Aux, should all have
similar sensitivities, and usually, impedances. Does your Kenwood have "
Pre Out - Main In " RCA jacks on the back, linked by patch pins ? If so, try
the Yammy's line out, into the " Main In " Jacks.
Please clarify exactly what the situation is regarding using the other
inputs on the Kenwood. I might then be able to get a better idea of what to
suggest you try next.
Arfa
