Look what I've been asked to fix now:
There's a few teardowns on YouTube (Dave Jones tried to fix a fault on one of these).
Bugger all documentation, and only a few voltages C/- Dave, so I'm not hopeful.
Everything after the data acquisition seems ok (not sure if that includes the memory).
The acquisition chips seem not to get anywhere near as warm as Dave's did (even allowing for the fact that I have the fan on).
My initial thoughts were a broken solder joint, but after feeling the chips, a failure of one or more rails is also a possibility.
This unit has a main SMPS power supply with an auxillary switch mode regulator board (possibly for extra rails), at least three (and maybe 5) switch mode regulators on the main board, and a couple of linear regulators. All up, the power supply stuff is hugely (overly) complex.
And yes, there are a couple of tantalum caps on the board :-D
Here's a better look at what the screen shows.
The vertical red lines flicker on and off. The yellow "trace" grows with time, although it can be cleared using the various functions (like reducing persistence). If you turn on other channels you get similar rubbish from them.
Connecting a channel to a signal doesn't seem to result in any difference in the display. If you try to use the math functions to give you frequency, period, etc, it tries, but you get meaningless and rapidly changing values.
I might try prodding at it with a wooden stick.
