D
DaveC
This scope has the famous "FAIL ++ Acq" error which points to the infamous
failed (and leaking) SMD caps on the acquisition PCB.
I'm moving on to troubleshoot another (unrelated, I think -- and hope) issue.
During the 25 second "on" period, relays click on & off, the monitor goes
through it's boot display (all bright, then dark, then the clock icon), then
the graticule is drawn, which is quickly replaced with the "Tek Running
Autoing" display listing the "FAIL ++ Acq" error.
During the power-up period, the front panel LEDs all turn on for about 25
seconds, then off for 5 seconds, then only the CH 1 LED lights.
The service manual says (in the Front Panel troubleshooting chart):
Do all
of the front panel
LEDs turn on and then
turn off a short
time later?
(Then
Does one
front panel LED
turn on and then turn off,
followed by the next LED until
all LEDs have turned
on and then
turned off?
The LEDs do not go through this one-at-a-time sequence. The manual's flow
chart points to a failed CPU PCB if the LEDs don't blink this sequence.
Can someone with a TDS4xx confirm power-on LED behavior?
I'm trying to determine whether, because the LEDs aren't blinking "properly"
and most of the front panel buttons are not working (the buttons bordering
the monitor, plus all the CH input buttons), does this mean a replacement CPU
PCB is in my future, or if it's possibly related to cap failure (ie, other
cap failures beyond the acquisition PCB)?
Has anyone else here have a similar problem (non-functional buttons) in the
past? I'd appreciate hearing your experiences.
Do all
of the front panel
turn off a short
time later?
(Then
Does one
front panel LED
on and then
turned off?
