tek 2235 scope p/s problem
P
pindiode
hi
i have a mil version tek 2235 scope
it is missing q908 on board
i think it is a scr.anyone have a scan
of the service manual p/s page?
thanks doug/aar3ir
Jim Yanik
t.com:
hi
thanks doug/aar3ir
If it is the SCR,it's in an overvoltage crowbar circuit,with a 51 V
zener,shorts a 3 ohm resistor to ground to put the PWM IC into 'burst'
mode. Tek p/n 151-0506-00,mfg.# C106B2X283(mfg=General Electric).
It's all part of a pre-regulator that knocks rectified line V down to ~43
Vdc for the power oscillator.
Sorry,I don't have any 2235 schematics.
The PS is similar to my 2213 PS.
The 51 V zener can also be out of spec and causing the SCR to trigger
prematurely.
M
Mike
The service manual lists Q908 as a PNP TO-92 transistor, mfg p/n 2N2907A, TI
p/n 151-0164-00.
Jim Candela
Doug,
I just checked Bama (bama.sbc.edu) an FTP web site. They have a 2225
Manual for download. Maybe that will help.
Good luck with that scope!
Regards,
Jim
P
pindiode
hello everyone
thanks for the help
i read some of the old posts
on this scope and should be able
to get it going now,thanks again
doug/aar3ir
T
TekMan
Jim Candela said:
Doug,
Regards,
Jim
...snip..
The circuit of the 2225 Scope is completely different to the 2235/2215
scopes.
And, as far as I can check this on bama, the 2225 manual is operating
only, not the service manual (so there are no schmeatics).
hth,
Andreas
Jim Yanik
[email protected] (TekMan) wrote in
..snip..
scopes.
hth,
Andreas
Yes,a 2213 or 2215 (or 'A' version) manual would be more applicable to
working on a 2235 PS.
An 'A' version manual would be most similar.
