U
unix-freak
Greetings all,
I have a monitor (Videoteknik) that I've been working on...and making
progress - I might add. It was a non working monitor when I got it, now it's
making pretty pictures....except....
When I have still video inputting it...the picture holds steady. When I have
moving/changing video..the picture shift vertically. I can scope the amp
output of the vertical IC and it shifts proportionally to the shifts on the
tube. It equates to 15 lines by my calculations.
The amp input also is shifting. It seems to shift whenever there are changes
from a bright image to a dark..or vice-versa.
I have no schematic...nor can get one. Does this sound like a problem in the
sync seperator circuit...or just a bad vertical cap or two?
Thanks in advance.
Thanks in advance.
