T flip-flop using opamps
R
Robert Monsen
Is it easy/possible to construct a Toggle flip-flop from either 3 op-amps or
3 comparators? I can't think of a way to do this, but it would sure make my
life easier...
Bob Monsen
Joseph Legris
life easier...
Bob Monsen
You can actually do it with just one op-amp. First, get a good one that
has the manufacturer's name and part number on the top. Then clip off
all the leads and place it on the desk. To toggle, just pick it up and
turn it over. It will flip to the opposite state and remain there until
you toggle it again. If it gets stuck in a meta-stable state, just knock
the desk with your knee.
Exercise: make a ripple counter with 2 op-amps and your little brother.
Joseph Legris
Jim said:
To do as you want, but without any kind of "memory" structures (the
caps and diodes), requires a master-slave approach.
...Jim Thompson
That's not a very nice way to refer to his little brother.
R
Robert Monsen
Thanks, Jim.
I'm looking to replace an underused counter due to power/space
considerations.
I'm guessing that I can do it with two by using some ideas from your T
flipflop schematic. Cross wire the opamps as inverters, and then use some
kind of diode/cap circuit to flip it on pulses.
Exactly what I was looking for.
Thanks again
Bob Monsen
