Synchronous motor
C
Carlos Saraiva
Hi
What is a 220VAC synchronous motor?
Is it a normal AC (2 or 3 wire) motor?
Carlos
John Popelish
Carlos said:
Hi
Carlos
Most AC motors are induction motors. That means that there is an eddy
current magnetic memory of sorts built into the rotor that holds some
of the field magnetism and gives the field something to work against.
This magnetic memory is constantly being refreshed as the motor turns,
but this process slips the memorized field slowly, causing the
induction motor to run a little slower than in synchronism with the
AC, with the slip increasing as the load torque increases.
Synchronous motors give the field a fixed magnetic structure to work
against. Either a chunk of iron with (salient) poles and spaces
between poles (synchronous reluctance) or permanent magnets. These
turn in strict synchronism with the line frequency, with only a phase
shift as load torque varies.
D
default
Hi
Carlos
Can be two or more wires depending on the number of phases and wiring
used. Simplest form is two wire single phase as used in some record
turntables, clocks, tape decks, etc.. Slow Syn makes a line of three
wire low speed synchronous motors (essentially wound like stepper
motors) that require a cap and resistor to shift the phase for one
winding.
C
Carlos Saraiva
Thanks.
Where can I find some schematics to learn more about this type of motors?
Carlos
C
Carlos Saraiva
Thanks.
Carlos
John Popelish
Thanks.
I don't have a favorite site for this. But I have given you many of
the key words needed to do a Google search. (salient pole, synchronous
reluctance, permanent magnet, synchronous AC motor) Adding the key
word 'tutorial' is often useful.
