R
RFI-EMI-GUY
I have a house in Florida built in 1980's. There is an underground
service entrance, a meter can and a main disconnect panel which serves
the sub panel in the house as well as a few circuits outside (pool pump
and pool lights). There is a ground rod bonded to the meter can. (main
ground rod)
I recently had a digital satellite antenna installed by Dish. The
installer chose to ground the dish to my pool pump ground rod which
appears to be isolated from the main ground rod.
Due to the poor grounding by the Dish installer, I chose to install a
series or rods around the sides and corner of the house encompassing the
dish installation, pool pump, main electrical service and the
telephone NIC box. (all these items to be bonded together) These ground
rods were spaced about 12 to 16 feet apart and bonded with #6 solid
copper conductor. After installing this supplemental ground system, I
confirmed that several volt differential between the new supplemental
system and the existing main ground rod (of unknown condition). This
test done without bonding the new supplemental system to the existing
main ground system.
It will be far easier for me to bond this new system to the
ground/neutral bus bar inside of the main disconnect panel than to work
inside the meter can. (requiring breaking the seal and working with live
conductors nearby).
Will there be any code violation or concern by attaching this new ground
system to the main panel as described above? Bear in mind, the
ground/neutral bus bar is connected by the neutral conductor to the main
ground in the meter can only a foot away.
Joe Leikhim K4SAT
"The RFI-EMI-GUY"©
"Treason doth never prosper: what's the reason?
For if it prosper, none dare call it treason."
"Follow The Money" ;-P
ground rod)
main ground system.
conductors nearby).
Joe Leikhim K4SAT
"The RFI-EMI-GUY"©
