Stepper motor model (K-179 unipolar driver)
mrel
Jul 2, 2008
115
Jul 2, 2008
115
Hello
Have anybody in this forum put together the kit ( k179 stepper motor kit together).
Question is after putting the kit together did the stepper motor kit K179 Work?
I put together the kit and cannot get the motor to move ,the motor is unipolar motor.
I notice the motor case get very hot and the motor Don't Move.
Anybody know what can be wrong with the kit?
I try two different motor i got both motor from all electronics
www.allelectronics.com.
(motor one) is CAT SMT-358 6-wire stepper motor 12 volts 8watt .
(motor two) unipolar stepper CAT# SMT-108 made by mabuchi# PF35T-48L4 7 volts 350MA.
Both motors don't move.
One of the IRFZ44N mosfet did get very hot after awhile with power supply to the pc board.
Thank any good infro.
Mrel
(*steve*)
¡sǝpodᴉʇuɐ ǝɥʇ ɹɐǝɥd
25,510
25,510
If the motor gets hot then you may be using it with too high a voltage.
If the mosfet gets very hot, check to ensure you haven't shorted the output somehow.
Do you have a link to a description of the kit? (preferably with a circuit diagram)
edit:there's lots more that could be wrong too -- just not enough info yet to be able to say exactly what
edit2: there's lots of matching kits. Not sure if they're all the same.
How many wires does your stepper motor have?
