Stabilizer for fridge, washing machine and Led TV
Discussion in 'General Electronics Discussion' started by Chandu10787, Sep 13, 2018.
  1. Chandu10787
    Chandu10787
    Sep 13, 2018
    Hi All,
    Kindly advise,
    I'm facing short circuit issue with my fridge LG, washing machine BOSH and my LED TV LG... please advise stabilizers which will help me counter the issue.
    Regards
    #1
    1. Advertisements
  2. Chandu10787
    Tha fios agaibh
    Aug 11, 2014
    1,664
    562
    If so that's rotten luck that they all are bad.
    I suspect you might have an overloading problem where one of these appliances overloads your service panel and the other things on the same circuit loose power.
    Putting surge suppression (stabilizer?) will not fix the problem.
    Are these all on the same circuit?
    Tha fios agaibh, Sep 13, 2018
    #2
    1. Advertisements
  3. Chandu10787
    dave9
    Mar 5, 2017
    414
    91
    Depending on the size and age of the refrigerator and washing machine, if they are on the same circuit then one starting up while the other is running may be enough to kick the breaker.
    Since you have little control over when the refrigerator cycles on, the solution is to not have them both on the same circuit unless I am misunderstanding what you meant, since you did not go into much detail about the problem.
    dave9, Sep 13, 2018
    #3
  4. Chandu10787
    kellys_eye
    Jun 25, 2010
    3,812
    1,023
    West Coast, Scotland
    Short circuit or tripping of the RCD?
    I suspect your are getting 'nuicence tripping' which is most commonly caused by defective motor capacitors in refrigerators, loose wiring and/or 'borrowed neutrals' in the distribution unit.
    Power the items separately and individually to determine which is the actual cause of the tripping. If they ALL cause it then check the wiring at the consumer unit and sockets.
    kellys_eye, Sep 13, 2018
    #4
  5. Chandu10787
    Chandu10787
    Sep 13, 2018
    It's short circuit and we could also find power in grounding
    #5
  6. Chandu10787
    kellys_eye
    Jun 25, 2010
    3,812
    1,023
    Caused by what? The TV? The fridge? The washing machine? They can't ALL be doing it.
    What form of circuit protection is fitted? Fuses? Circuit breakers? RCD's?
    Connect each device and see if the fault occurs on just ONE of them. If it occurs on them all then the WIRING is the problem, not the equipment. It would be a massive co-incidence if all those items all had the same fault........
    You need proper electrical installation test equipment to isolate the fault - earth resistivity/leakage detector, megger (insulation tester) etc.
    #6
  7. Chandu10787
    Alec_t
    Jul 7, 2015
    2,420
    630
    Wales
    Are you kidding? The TS Is in India :).
    Alec_t, Sep 13, 2018
    #7
    hevans1944 and Tha fios agaibh like this.
  8. Chandu10787
    Externet
    Aug 24, 2009
    588
    123
    Mideast US
    Chandu, what do you call 'short circuit' ?
    Externet, Sep 13, 2018
    #8
  9. Chandu10787
    7,233
    1,512
    Worcester, MA
    Short circuit is not a symptom. Tell us what you are seeing, and under what conditions, that make you think there is a short circuit.
    BobK, Sep 13, 2018
    #9
    1. Advertisements
