K
Kroko
Hello !
I am using a 628128 128K static ram. It has the control
line /WE /OE /CS1 and CS2. I have tied /OE and /CS1 to
ground. To control writing and reading I use /WE and CS2.
This works very well, no problem. I also select and deselect
the chip with CS2.
But I now changed the RAM type and am using a V62C518256LL
32K SRAM, because it has only 28 pins and I need space on
the board.
Unfortunately it doesnt have a CS2 but only /WE /OE and /CE
I thought it would be easy to modify my ram access to use this
chip, but it doesnt work:
I tied /CE to ground and use /WE as before. I use the same signal
as for CS2 to control the /OE line, just inverted.
Well, it doesn't work....
Do you have any ideas, why this is so ?
Kroko.
the chip with CS2.
the board.
Kroko.
