Sir Kim . . . . .
If you are now either fully stymied or stoooooooop-eeee- fried over your
no-workee-no-mo dilemma . . . . . . .and have come to a complete stop.
This should be close enough to the design concept which is used for that
units motor driver circuit.
Check the cluster of transistors in the unit and trace out a set of 6.
Initially confirm that none of the transistors are either open junction or shorted.
One associated motor lead will need to be lifted while confirming that.
If a cluster passes, then power up and confirm that your +6 VDC is reaching a
VT1 and VT2 sets emitters while the batttery negative is reaching VT3 and VT4
sets of emitters.
If that is true, then taking a 1k resistor from +6 VDC and connecting its free end
to either a VT5 or VT6 base should spin the motor in its respective directions.
Think up any related questions and I will answer them tomorrow.
Aside thought . . . . I think that sole mystery diode is going to be a lower than
6VDC . . . .4.7 ? 4.3 ? V . . 750MW Zener diode . that is maintaining a steady
regulated voltage to the receiver, since motor run action will be wreaking havoc
with the receiver supply line.
UNLESS it is run by a separate 9V ? battery . . . you tell me.
Thassssssssit . . . . .
BI-DIRECTIONAL MOTOR DRIVER CIRCUIT . . . . .
73's de Edd
