Sir bigkim100 . . . . . . aka . . .The " KIMSTER"
Your more incoming info. . . . . means the capability to then analyze it more fully and give you even more related analytical feedback.
I have seen one of your missing transmitter units, with its lil' piano wire whip antenna .
Look at the mark up photo and you can see the area within the base section that is marked with the
RED rectangle.
That is being the receiver section of the unit. It is composed with the
RED rectangular transistor that is being configured as a super regenerative detector AM receiver.
For tuning, it uses the
RED marked up, side by side, variable inductively tuned coil and a companion disc ceramic capacitor. By the wire gauge, coil form, turn count along with the spacing to the tuning slug, there is a VERY HIGH probability that this definitely operates on a slot within the license free 27Mhz citizens band, vice the later forthcoming 49MHZ and even later VHF and UHF spectrums.
The receiver sections detected output then feeds to the area within the
YELLOW rectangle which then interfaces into the
BLUE rectangles motor driver control section with its 2SD467 and 2SB561 transistor sets.
I potentially see three small motors and their reductive gear trains . Two for propulsion and one to spin the dome.
INSERT:
I would have to see connecting foil paths to that sole mentioned diode in the YELLOW / BLUE rectangle crossovere area to explain it,that areas foil is ALL covered with wires, close dressed to the board . ( So that they don't snag on the rotating dome above it.) BUT that diode is being FAR from the receiver portion . . .and assuredly being dissociative of it . . . and an extremely low probability of being of the germanium family.
Flipping a photo down, to the foil side of the board, there is the
RED star connection of the receiver input to the other
RED star designated serpentine foil etched antenna / aerial.
Its limited length is making it far- far- far short of a sub multiple wavelength at 27 Mhz, with any assistance probably being provided by a series inserted loading inductance.
The spread out spiral / serpentine pattern helps in giving it somewhat of an omnidirectional pickup pattern.
Its for sure that the
Acrylonitrile
Butadiene
Styrene outer housing did not receive a hot stamped silver mylar coating, as that certainly would have shielded antenna reception within.
Now for some aspects of the second photo down, there are the 4 pressure commutator leaf spring contacts that are now being marked with
RED squares.
This was back when they spent a little money to have the . . .suspected . . .phospor bronze contact areas . . . . being silver flashed.
You can see that it has now degraded to having one healthy and heavy BLACK coating of AGO
2 on their prior plated areas.
Looks like they spent a little more money on the
RED "A" boards top left corner, where a tiny bit of gold flash coating peeks out from the solder blob..
Its highly visible at the bottom of the RED "A" , and a bit shows at the top edge of the white break out wire tab..
ASIDE . . .
Looks like you might need to hit up Mamma Cass's dresser drawer and commandeer some of her Lady Eleanor silver polish cream to chemically clean those oxidized contacts, and buff back to a SHINY silver.
OR
Commandeer some of the ADMIRALS Brasso to clean them with.
OR
Commandeer one of great Aunt Nelly's typewriter erasers to erase off the oxide and clean the surfaces.
(What's a typewriter ? much less . . .there's a specific ? eraser made to be used with their type ?)
Now is where you will have to analyze and fill me in.
There are
RED B and
C pressure contacts with their domed contact points and spring pressure from their leaf type construction.
All of these above details can easily be made out on the
C contact, but the
RED LED's placement obscures the
RED B's contact dome. (Plus, in handling, it seems like the LED has ended up with it being askew from a right angle placement to the board )
Considering that there is a round PCB associated with the top rotating dome I perceive of that LED sticking straight up so that it then locates itself within a spiral circular slot cut within that PCB, so that the PCB disc can freely rotate around the stationary leaded LED.
Reflected light is making the leaf position of
B hard to see, but that contacts spacing up from the board below it should be the same as is
C and all of the springed contacts of
"A" assembly. They all then press into their contact areas to the PCB foils concentric contactor circles.
UNITS CONCEPT OF OPERATION . . . .(as is being perceived)
I suspect that the top dome is having its separate round PCB and a motor that permits the rotation of the dome.
Its power is being routed in thru the B and C contacts that are pressing into two separately spaced concentric spiral rings that have been etched onto the copper foil of the domes round PCB. That gets power transferred into the PCB and can feed in reversible polarity voltage to permit having a rotational motor, fed from a transistor driver circuit on the lower board. Therewith, it can then rotate in either direction, all in accordance to the end rotational limits designed within, and how you manipulate the remotes buttons..
I would suspect a couple of those ferrite dumbbell RFI chokes and green poly caps seen on the PCB, to be associated with quenching motor brush generated Radio Frequency Interference.
I can see the 4 contacts of
A assembly also aligned and pressed into its mating 4 concentric rings, also etched into the PCB of the rotational dome.
Those ring contact areas are broken up into small partial copper segments that can create connects between different spring leaf contacts, thus the changing tones, all in accordance to the domes rotational position, or where it comes to rest, if being stopped..
Now what I finally really -really think, is that there is being no problem with your suspect audio and and tone generator circuitry. The audio amp section is just setting there dormant, with no audio output into it, possibly excepting at power turn on with a feeble noise.
It is
THEN being dependent on DC triggering of the astable monostable multivibrator tone circuitry which I described earlier, then the audio emits.
OBSERVATIONS . . .
You see the very bottom left pic inset,
YELLOW squares, I am wondering if the round chromed fluted extrusion might be the power switch for the unit ? Plus the nearby LED might be a power on indicator.
Lastly . . . . your caution stickers. . . .just to the right. TELL that to a 2 year old that grabs it.
Thassssssssit . . . . .
PHOTO MARKUPS . . . . .
73's de Edd
