B
[email protected]
I've been trying some analog IC design but I'm running into difficulty
with things conceptually ("seeing" what is going on in the circuit) and
practically (getting something I've made to work, in simulation) - ie.
moving beyond what I was taught at university.
Specifically for the latter, I keep running into problems with getting
FETs to run in saturation. For example, an NMOS cascoded current
mirror: I've got the two cascoded input transistors on the left with
drain and gate connected, so no matter what, these will always be in
saturation. Then, connecting the gates of these biasing transistors to
the gates of two cascoded output transistors, with the same Vgs, the
output transistors should operate with the same drain current. But I've
got an active PMOS load above the current mirror and it is dropping
about 2.4V (with 2.5V supply rails), leaving only a few mV across the
drain-source of the cascoded output transistors, so that they operate
in their linear region instead of in saturation. The input transistors
have an almost identical load as the output, but as they have their
gate and drain tied together, they do stay in saturation.
So I guess my question is: how do I go about stopping the PMOS load
dropping all my voltage? The PMOS and NMOS transistors have W/L ratios
such that the PMOS is 1.5 times the NMOS, but changing these ratios
doesn't seem to have a significant effect on the output NMOS Vds.
Thanks for any enlightenment!
Bill
Bill
