Space-efficient control of multiple 12V 3.5A DC motors
Kaelin
Dec 13, 2017
5
Dec 13, 2017
5
I'm currently working on a project for which I'm looking to control six brushed 12V DC motors which each have a peak current draw of 3.5A. For a previous similar project, I used these motor controllers (https://www.robotshop.com/en/cytron-10a-5-25v-dual-channel-dc-motor-driver.html) which did their job very nicely. Unfortunately, the space I have to work with right now is quite constrained, so those controllers are pushing the limit of what I can fit in the environment; I'm looking for a smaller alternative which preferably doesn't cost too much more. I think I understand the concepts behind DC motor controllers pretty well, but my background is in CS and software development so I don't have the experience to be confident in this area nor have I worked with electronics past wiring up pre-built components and basic ICs on breadboards.
I've been doing some research and am having a hard time finding reasonable parts which satisfy my requirements. 1A and 2A motor controllers are available in abundance for cheap, but once you get above that it seems like the next major grouping is for much higher ratings and carry a proportionally higher price tag. I see a few options:
Am I missing options? What avenue of approach seems like it would be most appropriate for me?
Thanks!
Bluejets
Oct 5, 2014
6,942
Oct 5, 2014
6,942
Perhaps the rc range of brushed speed controllers?
May need a different control signal from what you are using (these are ppm)
Example here is a fairly wide voltage supply, forward and reverse with around 10A max.
Have no idea of the quality($5 ...:eek:) definitely smaller ........ but there are others.
https://www.ebay.com.au/itm/10A-Brushed-ESC-Two-Way-Motor-Speed-Controller-With-Brake-For-1-16-1-18-1-24-RC/301964699081?_trkparms=aid=555017&algo=PL.CASSINI&ao=1&asc=20160706105120&meid=3a7b53e7fff847848704698cf7589225&pid=100508&rk=1&rkt=1&&_trksid=p2045573.c100508.m3226
cheers Jorgo
Edit:...sorry...didn't notice these are 7 cell nicad so under your 12v requirement.
However there are others as I said.
Kaelin
Dec 13, 2017
5
Dec 13, 2017
5
cheers Jorgo
Thanks for the tip! I did some research on RC-focused options and am hitting a few issues:
Is there something I'm doing wrong in my search? Do you have any suggestions?
Thanks!
Bluejets
Oct 5, 2014
6,942
Oct 5, 2014
6,942
Don't think so. Trend these days is more biased towards the use of brushless in the r/c environment at least. These use supplies of varying voltages but common to see anything from the7.4v to 22.2v (lipo batteries). Don' t suppose you'd consider a change in motors? There can be advantages such as size but may have to consider cooling.
Bluejets
Oct 5, 2014
6,942
Oct 5, 2014
6,942
Kaelin,
Found these "r/c boat esc" with forward /reverse and 6 to 12v operation.
Don't let the 320A throw you, it's just a max level ( mmm..... maybe on Mars I think)
https://www.ebay.com.au/itm/320A-6-...439964&hash=item3ae92d640a:g:VTYAAOSw6ShZVlHK
43mm x 29mm x 27mm
Just be aware that most of these esc units need to "armed" at the power-up stage.
This means the throttle (speed) needs to be initiated at full up after power-on and then reduced to zero setting for the controller then to work. It's a safety feature to avoid getting ones arms/legs chopped at power up from an rc set to max throttle accidentally.
Some may require "programming" also but it is normally a fairly straightforward process utilizing a series of led light flashes etc. Mainly to set things like brake on or off, set points ( maximum travel in reverse) for things like boats where max reverse would drown the poor thing.:eek::eek::eek:
Another thought was, that if your speed between motors is not required to be absolutely the same, you may get away with all 6 motors on the 1 controller. Just suck it and see I guess. Good luck.
