Sir Daryl . . . . .
WHERE? . . . . .you . . . .g o o o o o o o o o o o o o o ?
latest update is that this deck now has no power lol its lifeless and i need it to work again any help appreciated.
If that is the case, then take ohmmeter and test across the AC cords plug to see if you are reading tens of ohms resistance of the transformers primary winding.
IF SO . . . . . . . . .
Those are being fusible resistors that will that blow open circuit, in case of excessive .overload.
R704 at the top is a given, in its wired installation.
The lower R700 or R703's options are being incorporated in accordance to different -11,-12 or -13 board versions
Starting all over again . . . . .
Why don't you start by using a DVM and connect its black ground lead to the central ground buss that crosses the unit .
THEN power up and check with DC metering to see if you find the bottom left corners MINUS 28 VDC supply being present.
Then move up to check for the presence of the +5 and +11 VDC supplies..
Then, move to the extreme right of the board and check for presence of the +7.5 VDC supply at the top left corner and then check the bottom right corner to see if the MINUS 7.5 VDC is present..
Clue us in on what supply is missing . . . and we can then proceed.
Sort of expecting your +5 and / or / + 11VDC to be missing.
If that is the case . . .switch metering to AC mode and check for the presence of the ~15 VAC across power transformer terminals #11-13. Then stay on one lead and move one probe to #12 to see if it is reading ~ 1/2 the previous voltage being read.
73's de Edd
