B
BWL
This is the one with the H.V. board mounted on a metal box on top of the power
supply; uses STK4278L's for convergence. Convergence working fine, but pic has
obvious horizontal and vertical pincushion distortion. I'm hoping somebody has
seen this problem on this type chassis before, since I don't have the 15 piece
Sony service cable set, and the service manual is a reprint, with the large
schematics cut into eight pieces and sequentially bound into the manual(what a
pain). It's NOT the convergence circuit, as I have +/- 17 volts to the IC's and
they are running normally warm (hot). I could almost get it corrected using the
adjustment pots, but that's not the right way to fix this; any help?
