Sonoff Motor Alexa Voice Control
Discussion in 'Sensors and Actuators' started by Alex Reid, Feb 14, 2018.
  1. Alex Reid
    Alex Reid
    Feb 14, 2018
    Hi all,
    I have a TV lift which will go up and down using an RF remote.
    I want to add the Sonoff Mini switch directly so I can raise and lower the lift by commanding Alexa and google. This should be possible although I am a bit of a novice and it is unclear where this needs to be wired in. I have seen Sonoff used to raise and lower blind motors and garage doors
    In the photos you can see my mistake, power is going into the Sonoff however it will not interact with the lift.
    If anyone has advice on how to make this work I would appreciate it!
    #1
