Paul Bealing said:
Come on; that's not a very sensible reply.
Presumably you actually are that stupid.
Oh well, we need some natural selection now.
There are naturally safety issues with high
voltages and water, but there are solutions.
Yeah, like using 24VAC, stupid.
I wouldn't recommend hobbyists play with high voltages.
You just did, stupid.
There is also the issue of legallity considering
that your're only just still allowed to approach
with 10 feet of an electrical appliance.
Wanna try that again in english this time ?
I have found that cheap 12V DC solenoids overheat
if left on for more than 20 or 30 minutes at a time.
So it makes a lot more sense to use the
ones designed for the job that dont, stupid.
We were getting the cheap ones for about
$15 each in low numbers (a few at a time).
What matters is the electrical safety and the law, stupid.
The other post recommending a lower hold voltage once
energised is a good idea. I would recommend a few experiments.
And are obviously stupid enough to suggest the use
of 240VAC solenoids in that particular application.
I did find that a good margin was required to prevent
dropout due to water pressure fluctuations and vibration.
All MUCH less important than the electocution risk, stupid.
I would recommend cheap appliance type
12V AC or 24V AC (if available) solenoid
valves for a home made watering control system.
You in fact were stupid enough to
recommend 240VAC solenoids instead.
Ensuring ventilation and mounting in the shade, if outside, will help.
Varying the duty cycle will also help; on-off-on-off etc.
Waffle completely irrelevant to the comment
I made about the terminal stupidity of using
240VAC solenoids in that particular situation.
Do you have any comments that
may be helpful to others listening in?
Already made those about the terminal stupidity of using
240VAC solenoids in that particular application, stupid.
