Soldering Tiny Wires Query
Discussion in 'Electronic Design' started by edvogel56@gmail.com, Jan 9, 2014.
  1. Guest
    Yesterday I discovered a technique for soldering wire wrap 30 AWG wire in tight spots and was wondering if anyone else may have tried this.
    I took the finest tip I had which is about a 0.5 mm dia on the point end and used an Xacto knife to score a V slot. This little slot aids in making solid mechanical and thermal contact with the 30 AWG wire.
    Questions:
    1. Anyone else tried this or similar?
    2. Anyone know of commercially available "V tips" for soldering.
    Thanks in advance.
    EdV
    , Jan 9, 2014
    #1
    1. Advertisements
  2. Guest
    I would think this would damage the plating of the tip and once it corrodesit will no longer "wett" well at that spot.
    Mark
    , Jan 9, 2014
    #2
    1. Advertisements
  3. Don Y Guest
    Hi Ed,
    I've seen tips that look like a "forked tongue" (not sure if this is
    where you imagined making the notch vs. along the "length" of the
    tip)
    Don Y, Jan 9, 2014
    #3
  4. Nico Coesel Guest
    Better use a good iron with a relatively big tip at the proper
    temperature (330 deg C). The secret to soldering is to use a bigger
    tip than seemingly possible. Small tips lack the thermal mass and
    conductivity to heat up a joint fast enough so the flux burns up
    without doing anything.
    Every now and then I solder wires as thin as a hair. The thinner the
    better because surface tension pulls the wire right into the soldering
    joint. Things can't get easier.
    Nico Coesel, Jan 9, 2014
    #4
  5. Guest
    Nice! Mine worked but the metal is more bent out of the way than actually removed.
    , Jan 9, 2014
    #5
  6. Guest
    It's the space constraints of the already crowded PWB in this instance that led to the modified tip. I often solder a 40 AWG wire strand then add insulation and strain relieve it and solder to another strain relieved wire bit there wasn't room this time.
    , Jan 9, 2014
    #6
  7. Den torsdag den 9. januar 2014 21.00.08 UTC+1 skrev Jon Elson:
    I use enamel wire, no messing around getting the insulation off,
    just dip the cut end in a blob of solder on a hot iron
    -Lasse
    Lasse Langwadt Christensen, Jan 9, 2014
    #7
  8. Do you have a tweezer type? Really fast and little possibility of
    damaging the board.
    The German Weller type is nice, but I've also noticed some knock-off
    designs for a fraction of the price.
    --sp
    Spehro Pefhany, Jan 9, 2014
    #8
  9. Usenet Line length is 72 characters.
    Your contact does NOT need to be that intimate. That is why you do
    NOT see it anywhere else in the industry.
    I'll bet you plowed up a lot of pads and tracks in the thru-hole days.
    At 30Ga., all you need is a tiny drop of solder on the end of the tip.
    The flux is already at the solder joint location (or should be). A mere
    touch of the tip to the entire connection node, and a reflow occurs, no
    need to dig, plow, or gain weldement level conduction of the elements
    involved.
    The old Heathkit training is no longer valid.
    Sheesh. Oh, and 30Ga wire is for point to point, and SURFACE attach.
    Putting on into a through hole or via is asking for it to get broken.
    For that, you want strands.
    DecadentLinuxUserNumeroUno, Jan 10, 2014
    #9
  10. Chris Jones Guest
    Yes, without the protective iron-plating, the copper core of the tip
    will dissolve in the solder, and won't last long.
    A small drop of fresh solder and perhaps a slightly bigger tip will fill
    any gaps and ensure excellent thermal contact and this avoids the need
    for desperate measures.
    Chris
    Chris Jones, Jan 10, 2014
    #10
    1. Advertisements
