I've recently started tinkering with ESP8266 boards, and one of the projects I'm going to build will involve having the board sitting outside for years recording data (this pond water level meter).
It would be ideal if I could use a LiFePO4 battery, which is trickle charged via a small solar panel throughout the day. I'll then tune the sleep cycles of the ESP8266 so that it should work even when there is minimal sunlight throughout winter.
Is anyone aware of any modules that will allow me to simultaneously charge (using a solar panel) and use a LiFePO4 battery? It looks like I could create my own using a MCP73123, but I'd really like to use an off the shelf module for prototyping - there are plenty of modules for this on AliExpress for normal Li-ion batteries, but none that I can find for LiFePO4 batteries.
