P
peter
An ex spilled some cola in my car and some got inside the cd/radio. Since
then, the push buttons on the radio only work 10% of the time. 90% of the
time the buttons do not respond. It's a radio/CD player I cannot change
stations at will, and am afraid to put CD in it (the eject buttons also only
work 10% of the time).
I removed the radio, separated the faceplate -- that's where I believe the
soda was splashed. Sure enough I see droplets of dried soda. I dip the
faceplate/buttons in water in an ultrasonic cleaner, taking care not to dip
the LCD portion.
Then I let the faceplate air dry for a few days. Then put it all back into
the car. Then, the buttons work perfectly again.
BUT, after a few days, the buttons return to the 90% not responding
symdrome.
I repeated this cleaning procedure twice. Each time the same end results.
Anyone wants to theorize what may be happening?
Now I have another idea: instead of water, dip the faceplate in denature
alcohol -- that is what some people do to treat cellphones dropped in water.
My only concern is, since alcohol is a solvent, could it dissolve some
components in the faceplate? Any suggestions on what electronic components
may be damaged by alchohol? If I only soak it for a short time (e.g. 30
sec), there should not be enough time to dissolve anything, right? I'm
willing to take some risk because a 10% radio/CD is very frustrating.
the LCD portion.
symdrome.
