smps controller IC datasheet?
Discussion in 'Electronic Equipment' started by DaveC, Aug 14, 2013.
  1. DaveC
    DaveC Guest
    oem power supply, 31.5 vdc 1.5 A.
    I want to change the output to 24 v.
    There is one 8-pin IC, labeled:
    230D1
    PUICO
    I don't see a datasheet anywhere for this.
    Any ideas?
    DaveC, Aug 14, 2013
    #1
    1. Advertisements
  2. DaveC
    DaveC Guest
    DaveC, Aug 15, 2013
    #2
    1. Advertisements
  3. DaveC
    DaveC Guest
    > Probably a custom chip specific to that assembly (or company,
    > actually). The board it is on looks pretty cheap... single layer even
    > (practically)
    > When they make several M number of pieces, they get to make custom
    > dies. Just a guess.
    It is an OnSemi PWM controller:
    <http://www.onsemi.com/PowerSolutions/product.do?id=NCP1230>
    The board is a 5-layer. Here's the other side of the board (the LV end):
    <http://oi42.tinypic.com/102w1go.jpg>
    This is a ASTEC ps from a large HP inkjet printer.
    DaveC, Aug 15, 2013
    #3
  4. DaveC
    DaveC Guest
    > The one you pointed to is fixed freq, so there won't be a pair of pins
    > for setting the frequency.
    It's a simple 2-resistor voltage divider on the output which determines the
    output voltage. I'll replace one of these with a pot -- for trials -- then a
    fixed R when the value is determined.
    Thanks.
    DaveC, Aug 17, 2013
    #4
    1. Advertisements
Similar Threads
  1. Michael
    SMPS controller
    Michael, Oct 20, 2003, in forum: Electronic Design
    665
    Anantha Narayan
    Oct 21, 2003
  2. Dave Moore
    2,952
    Dave Moore
    Sep 22, 2007
  3. Replies:
    2,956
  4. eem2am
    SMPS controller IC with HV start-up module
    eem2am, Aug 18, 2010, in forum: Electronic Projects
    987
    Militoy
    Aug 24, 2010
  5. DaveC
    DaveC, Aug 14, 2013, in forum: Electrical Engineering
    5
    1,813
    DaveC
    Aug 17, 2013
  6. DaveC
    DaveC, Aug 14, 2013, in forum: Electronic Components
    3
    1,416
    DaveC
    Aug 17, 2013
  7. DaveC
    DaveC, Aug 14, 2013, in forum: Electronic Design
    5
    487
    DaveC
    Aug 17, 2013
  8. RobertMacy
    111
    3,072
    josephkk
    Oct 24, 2013
Loading...
