Small bulbs always burning out.
Discussion in 'Lighting' started by Peter Jason, Feb 9, 2013.
  1. Peter Jason
    Peter Jason Guest
    I have a truck with a plurality of lamps, of 12V,
    21W.
    They don't last long and replacing them is a
    tedious chore.
    I want to reduce the voltage to each bulb to take
    the load off the filament and so extend its life.
    They are bayonet fittings, and so I seek a small
    thin disk of some resistive material to put into
    the lamp socket to contact the center terminal, so
    that when the bulb is inserted this will act as a
    resistor so reducing the voltage by a small
    amount. Clearly the inserted bulb will hold the
    material in place.
    What can I use? Graphite, iron, lead, or some
    form of nichrome? Is there any other
    low-conductive material available in sheet or disk
    form?
    I am sick of replacing these bulbs, and they're
    not cheap!
    Please help, Peter
    #1
    1. Advertisements
  2. Peter Jason
    Guest
    Sounds like the 1156 (ANSI number) that was popular in older US cars
    and trucks. Usually available for about $1 apiece, cheaper if you
    buy a box of 10 at NAPA. For a little more money you can get a "long
    life" version with approximately twice the rated life.
    How's your electrical system? If you see much over 14.0 volts at the
    battery, or over about 12.8 volts at the fixture, with the engine
    running at 2000 rpm (gas/petrol) or, say, 1500 rpm (diesel), fix that
    first and your lamps will last longer.
    Were the fixtures installed by the manufacturer, or a later addition?
    If added later, how well are they mounted? Loose and floppy fixtures
    burn out lamps. Are they well sealed? Water leaking in will burn out
    lamps.
    This also makes it dimmer, which makes your truck harder to see.
    Dropping the voltage to 90% of rated voltage will make the lamps last
    about three times as long... but it will also cut their light output by
    about 30%.
    There are LED replacements available, but they usually send all the
    light in one direction, which is not a good match for the original
    lamp. The fixture will be highly visible from one direction only and
    hard to see from all other directions.
    Normally, if a voltage reduction is needed, it is done inline with the
    wiring to the fixture.
    Matt Roberds
    , Feb 9, 2013
    #2
    1. Advertisements
  3. Peter Jason
    Peter Jason Guest
    lamps.
    about 30%.
    Matt Roberds[/QUOTE]
    Thank you. I've just realized I can wire suitable
    no of lamps in series and effect a reduction that
    way.
    Peter Jason, Feb 10, 2013
    #3
    1. Advertisements
