NachoohcaN
- Mar 19, 2018
- 1
- Joined
- Mar 19, 2018
- Messages
- 1
I have a battery powered speaker system which is powered by a 12V lead-acid battery (7.5Ah). I am looking to increase the amount hours of use I can get out of the unit and I see there are a couple different options. I'm a little confused about each...
The speaker system has a 12vdc 2a charge port on the back. Meant to be used, say, with cigarette lighter port inside your car, or one of those battery boosters with a 12v out port. I'm wondering if I could use a Lithium-ion jump starter to charge the battery. I've been looking at this one...
https://www.primecables.ca/p-360792...edium=display&utm_campaign=primecables_criteo
I understand that this unit is meant to jump start SLA batteries but what about charging them with the 12v out port? Can you charge an SLA battery with a lithium ion jump starter? A little confused here.
Another option....
If I were to increase the Ah by adding another SLA battery inside the unit (wired in parallel ofcourse) do I have to use the another battery with the same Ah? I am looking to keep the unit light-weight and adding another 7.5Ah battery is a lot of weight. Could I add a 4aH SLA battery in parallel? How does the depletion/charge of the batteries work if they are different Ah?
What would be the best way to add more Ah to this unit. Any help is appreciated! Thank you!
Another option....
