Single power supply for 2 devices
eob2000
Jun 14, 2015
7
Jun 14, 2015
7
I have 2 DC powered devices that have their own AC adapters. I want to use them in a project together but want only one power connector. The first device is 12V 1.5A and the second device is 5V 2A, I want to power the project with an external power supply, I thought a laptop charger but the one I have is only rated for 3.34A. I am very new to electronics, I assume that my 19.5V 3.34A power supply cannot power 17V 3.5A, Please correct me if i'm wrong. Regardless please can someone tell me how to achieve this split output (Even if I need a new supply)
Thank You
davenn
14,264
14,264
hi there eob2000
yes, you are not correct ... a few problems with your understandings there
OK that's good ... so you need to create those 2 voltages from a single input that's higher than the largest of those 2
the 12 and 5 DONT add so it's not 17V you need ... see my first comment
you can use the 19V 3.34A laptop supply at a pinch preferably you really need a 5A one to get some headroom
this is the sort of thing you require ....
http://www.ebay.com.au/itm/DC-DC-Ad...9cc6d&pid=100338&rk=18&rkt=29&sd=251730814512
from your 19V supply, you need 2 of them, one set to 12V and one set to 5V
the other way is to get a 12V 5A PSU and supply the 12V device from that and from the 12V line use just one of those buck converters to produce the 5V line
davenn
14,264
14,264
an extra comment on current requirements ....
current requirements DO add, ....
ohhhh ..... before I get into that ..... is the text on the devices plugpacks say 12V 1.7A and 5V 2A or is that what is stated on the devices themselves ? this is important
if it's what is on the devices then you have 2A and 1.7 A and that adds to 3.7A and your laptop supply is 3.34A max
do you see a problem ?
That's why I said earlier that you need a 5A capable supply
eob2000
Jun 14, 2015
7
Jun 14, 2015
7
The info is from the plugbacks, unfortunately neither device has and power requirements. printed on them
One of the devices is a IDE-USB unit being used to connect a HDD (the 12V device)
The other is a powered USB hub, I am powering various things including a raspberry Pi so I believe I will need the full current (the 5V device)
davenn
14,264
14,264
OK that is probably an advantage to you as those will be the maximum ratings for the 2 PSU's
meaning that the current drawn from them is likely to be a bit lower
Give the 19V 3.34A laptop supply a go with 2 of those buck converters from eBay and see how you go :)
