A
Andy
I've been revisiting my op-amp theory, and note that there are cicuits for
voltage-voltage amplifiers (non-inverting ), current-voltage amplifiers (
see-saw or inverting amplifier ), but that it's a little more obscure with
voltage-current and current-current amplifiers.
I've managed to derive the last two configurations but the load is floating
in both cases. Of course I understand that, for instance, a voltage follower
provides current gain,
but it is not what I would call a voltage-current amplifier, the reason
being that if you were to change the value of the output load, the output
current would change too ( as the o/p voltage remains constant ).
A real voltage-current amplifier would give a gain of a constant value of
Amps/Volt, even if the output load varied in resistance. Same with a
current-current amplifier, it would have a constant gain of whatever
Amps/Amp even if the load varied i.e it would apparently have a current
source output.
So, has anyone come across either of these last two mythical beasts, with,
like I say, a non-floating load ( i.e. one end referenced to ground ).
thanks,
Andy.
source output.
thanks,
Andy.
