Sine Wave from Square wave
vinit2100
Oct 21, 2013
100
Oct 21, 2013
100
I want to generate a sine wave from LTC6900 which gives a square wave output. Please help me designing.
vinit2100
Oct 21, 2013
100
Oct 21, 2013
100
That is a Tuned Band Pass Filter IC UAF42. I cant afford that IC . It costs around 15$. any other alternative for this ?
LvW
Apr 12, 2014
604
Apr 12, 2014
604
If the frequency is fixed you could use a self-designed lowpass or bandpass filter (the necessary order is determined by your distortion requirements: Quality of the sinus signal).
However, a filter that can be tuned together with the varying frequency of the squarewave is harder to realize.
KrisBlueNZ
Sadly passed away in 2015
Nov 28, 2011
8,393
Nov 28, 2011
8,393
How about answering some questions first.
Will the frequency of your square wave be variable?
What is the frequency range?
How quickly will the frequency change? Can you tolerate some distortion while the filter settles to a new frequency?
What is your budget?
vinit2100
Oct 21, 2013
100
Oct 21, 2013
100
Using LTC6900 we can set the output frequency . I will set that frequency to around 2khz. Budget in a sense means, I can afford huge cost IC
LvW
Apr 12, 2014
604
Apr 12, 2014
604
ok then how will i design a filter ?
There are many, many introductory articles accessible through the Internet which can teach you filter design basics. I don`t think that it is possible to do that in a forum like this.
7,682
7,682
If you need only a fixed frequency, why not make an oscillator that produces a sine wave instead? It is easier to convert a sine to a square wave than what you are trying to do.
dablakh0l
Sep 19, 2014
11
Sep 19, 2014
11
Or build a cheap sine wave generator from an op-amp and some r's and c's
vinit2100
Oct 21, 2013
100
Oct 21, 2013
100
Ok lets make a oscillator circuit. But my requirement is i don't need the sine waves always. How will i control the oscillator then ? I want to turn ON/OFF oscillator !!!
7,682
7,682
With a switch?
Why don't you tell us what you are trying to do.
