I am making simple voltage multiplier pcb's for some bug zappers that i build. My problem is that I can double the voltage fine, but as i try to triple or quadruple the voltage, the voltage goes down instead of up. I am starting with 110v ac and should end with 400+ volts after quadrupling the voltage. My components are 1n4007 diodes, and 394J 400V 0.39UF film caps. The circuit is layed out properly as far as I can tell. I attached the circuit diagram I am using. Are my components limiting the voltage?
I have tried higher voltage caps but the result is the same.
