simple resistance calculation exercise
Discussion in 'Electronics Homework Help' started by endlessparadox, Sep 5, 2018.
  1. endlessparadox
    endlessparadox
    Feb 14, 2018
    20
    The first image is the exercise the second image is what i have done can someone explain me what is my mistake?
    And is there a simpler way to do it?
    #1
    1. Advertisements
  2. endlessparadox
    Robert_fay
    Jun 15, 2017
    117
    32
    No you are doing this wrong. You need to start at the end with R5 and R6 and work backwards to find total resistance for the circuit. Once you have that you can figure total current for the circuit. Once you have current you can work forwards and on your parallel and series circuits to calculate power.
    -Robert
    Robert_fay, Sep 5, 2018
    #2
    1. Advertisements
  3. endlessparadox
    endlessparadox
    Feb 14, 2018
    20
    Which means R5+R6 as series parallel with R4?
    #3
  4. endlessparadox
    24,477
    2,442
    yep, and so on...
    (*steve*), Sep 5, 2018
    #4
  5. endlessparadox
    Ratch
    Mar 10, 2013
    1,002
    293
    Do what? I see no definitive statement from you about what you want to do. Is it "A", "B", "C", "D", or all the above? Why not submit the image in landscape format instead of portrait format so we can view the problem without lying down and avoid the truncation of "A" ?
    Ratch
    Ratch, Sep 5, 2018
    #5
  6. endlessparadox
    Ratch
    Mar 10, 2013
    1,002
    293
    That will work, but it is the hard way to do it. A easier and quicker way is to use node analysis to find the voltages at the R1-R3 node and the R3-R5 node. Two equations and two unknowns. Once those two voltages are known, then anything else can be easily calculated.
    Ratch
    Ratch, Sep 6, 2018
    #6
  7. endlessparadox
    ratstar
    Aug 20, 2018
    40
    Another way to do it, thats kinda still a bitch to do...
    Is to just draw each loop from the battery separately, and then complete the resistance calc of each loop, then add them up to get your amps - for all locations on the circuit. (where the loops overlap, you have to count all loops go over that line.)
    Thats almost it, except you have to take into account load hogging when the loops come apart from each other.
    ratstar, Sep 6, 2018
    #7
    1. Advertisements
