Hi all,
I am not the greatest electronics engineer in the world, but I know my way around a soldering iron and the basic principles of electronics.
I've adapted the tutorial on instructables for a passive 3 input stereo mixer in a die cast box, but I'm not sure about the level of resistance being applied.
I'm looking to mix my stereo out from my TV and the headphone out from my Echo Dot into one channel on my HT Amp.
I have wired up 5 inputs on my new mixer, for expansion.
I have two RCA Phono pairs and Three 3.5mm socket inputs.
Each input channel, left and right, is run through a 4.7k resistor before being soldered together and joining the main out channel on the "Line Out" 3.5mm connector.
So I have 10 resistors in total, with the grounds from each of the connectors joined together with the ground from the Line Out connector.
The problem is that the volume is now so low that I can't hear the TV even on max volume.
Could the same effect be gained from downgrading to 1k resistors?
