SIM project
Discussion in 'Microcontrollers, Programming and IoT' started by ocean750, Feb 16, 2017.
  1. ocean750
    ocean750
    Feb 16, 2017
    5
    Hello.
    I would like to send commands to hardware by use of a SIM card.
    for starters, as an example, activate a LED, and receive a button being pressed.
    are there examples of such projects ?
    Thank you,
    Ocean
    #1
    1. Advertisements
  2. ocean750
    Kaare Jenssen
    Feb 22, 2017
    6
    Hi.
    Key question: What kind of hardware do you have/want to use/What is your background?
    The easiest way for most people without prior knowledge would be Arduino with GSM shield, or a Raspberry Pi with a GSM module. The reason is due to the simplified programming (no need for assembly, writing library code etc), and the amount of documentation for these devices.
    That being said, I suppose it deponds on your programming background, and if you are an electrician, if you want to use ladder logic or programming languages like C/C++ and even assembly programming or to be able to easily use java, .net etc.etc
    You can find step by step instructions for most common devices for the task u describe, and for the arduinos and raspberry pis, there is overwhelming amounts of tutorials and picture guides etc.
    There is really no better friend for this question than google.
    Kaare Jenssen, Feb 23, 2017
    #2
    1. Advertisements
  3. ocean750
    ocean750
    Feb 16, 2017
    5
    Thank you for replying.
    ocean750, Feb 26, 2017
    #3
  4. ocean750
    Wilksey
    Mar 3, 2010
    11
    Arduino + GSM Shield, this will take your SIM, most come with examples, but your best bet is to download the "AT Command" set for the chipset (say SIM900 for example) and see what each command does.
    You will find some commands are common across GSM chipsets, some might have slightly different parameters, and all will have their own proprietary AT commands.
    Wilksey, Mar 10, 2017
    #4
    Arouse1973 likes this.
  5. ocean750
    ocean750
    Feb 16, 2017
    5
    Thank you :)
    ocean750, Mar 11, 2017
    #5
  6. ocean750
    SalRu
    Mar 16, 2017
    12
    Hello!
    Arduino and GSM module are the best solution! You can send "AT-COMMANDS" with the UART protocol from arduino to GSM and it will automatically send the SMS.
    When you receive an SMS the GSM send a String through the UART to arduino where you can compare to a string in the memory and act depending on what was written in the SMS
    Hope to be helpful!
    SalRu, Mar 16, 2017
    #6
  7. ocean750
    ocean750
    Feb 16, 2017
    5
    Hi.
    Thanks for the replay.
    can you direct me to a sample project ?
    one that I can copy and move on from there ?
    ocean750, Mar 16, 2017
    #7
  8. ocean750
    Kaare Jenssen
    Feb 22, 2017
    6
    Here is the library reference and example codes for the GSM communication.
    https://www.arduino.cc/en/Reference/GSM
    However, I would recomend you read this getting started guide before you do anything else, just to get to know how the Arduino works.
    Kaare Jenssen, Mar 18, 2017
    #8
  9. ocean750
    ocean750
    Feb 16, 2017
    5
    ocean750, Mar 25, 2017
    #9
    1. Advertisements
