P
Peter
I must be going stupid here but sure the answer is YES.
Take a 10A shunt for a 100uA moving coil meter whose resistance is say
1k and thus 100mV FSD.
The shunt (about 0.01 ohm) is going to be a very low impedance
*voltage* source to the meter.
The 100uA meter is 100mV FS but obviously what makes it move is
current, not voltage, but the current it draws is going to vary with
the tempco of the wire it is wound with.
So, surely, the shunt should be copper so that the output of the shunt
tracks the meter movement sensitivity.
Unless the meter movement is wound with nichrome... is it? I have
never heard of that.
All the shunts I can see are nichrome or similar which is surely wrong
for use with a copper-wound meter?
