Series Resistor and TVS diode placement
Discussion in 'Electronic Design' started by mahen, Jan 9, 2014.
  1. mahen
    mahen Guest
    If I have to put ESD diode and current limiting series resistor to protect the IO pin of MCU from ESD and over current, which is the suggested way?
    MCU Pin -------------- Series R -- TVS to GND -- Connector
    or
    MCU Pin -------------- TVS to GND -- Series R-- Connector
    With the 2nd option, doesn't the R limit the surge into TVS needing only lower wattage ESD diode compared to 1st option?
    -mjnk
    mahen, Jan 9, 2014
    #1
    1. Advertisements
  2. With the second option all your surge current is running in the series R and it would need to be either of very small resistor value or large power handling value to cope with the surge energy
    This way:
    MCU Pin ---- Series R ------External ESD diode ------ Series R -- TVS to GND -- Connector
    TVS takes blunt of the surge pulse. Resistor limits current into series ESD diode. Second resistor limits current input MCU pin to avoid latchup (normally you need to stay below 1mA depending on the die technology)
    Cheers
    Klaus
    Klaus Kragelund, Jan 9, 2014
    #2
    1. Advertisements
  3. mahen
    RobertMacy Guest
    Jim, be careful of using zeners as circuit protection. They turn on
    EXTREMELY slowly and during that time can let a lot through.
    For grins, take two 5.6V zeners and put in series 'facing each other' as
    feedback on a high speed OpAmp. Then drive the thing and you won't get a
    square wave out, you'll get an extremely 'spikey' square wave out. We're
    talking audio frequencies, too. I've seen 20kHz spikes.
    Do again with tranzorbs and you can really see the difference.
    Or, you can do what we used to do, slightly turn the zener on ahead of
    time, that helps. but takes a fast switching diode into the turned on
    zener. Today, too many parts, then, the only way.
    RobertMacy, Jan 9, 2014
    #3
  4. mahen
    RobertMacy Guest
    How about RF beads instead of R's, they're almost the same physical size. ?
    Then you get the equivalent of over 1k to 10k ohm series resistance, but
    at the operating frequencies of the component, very low impedance, so you
    don't end up compromising waveform shape, too much.
    #4
  5. mahen
    RobertMacy Guest
    Right. is that before or after the esd diode burns up? or when the series
    resistor burns up, what are these 0402's 1/64 w ??
    I usually use series R and RF Bead, to get a 'well-rounded' response.
    #5
  6. mahen
    RobertMacy Guest
    What you can 'get away with' and what happens are two different things.
    For example, I don't use an anti-static wrist band, nor am very careful
    about handling components, no problem. Sure, no problem ...today! but
    probably shortened their little lives so they'll fail in anywhere from 2,
    6 months out to one year, instead of lasting 10 years.
    And, optocouplers? not quite the panacea one would expect. kind of work
    for AC mains isolation and some on voltage protection, except capacitive
    coupling high voltage can still 'punch' through. and worst of all magnetic
    pulses [even the pulses caused by HV discharge from HV protection], just
    go right around an optocoupler. EMP's can do a LOT of damage. All a
    manner of degree.
    For total protection, I like to think in terms of analog filtering
    components. the uP has C and limit [low Z], therefore place a high-Z in
    series, then place a low-Z to GND, and then a high-Z out to the unknown
    origin. [this is a judgment call, because using a low-Z here can result in
    a spike of current injected into the GND plane and/or inject a current
    pulse into adjacent circuitry] And, be sure to design for at least 3GHz
    spectrum and you should be ok.
    #6
  7. mahen
    RobertMacy Guest
    NO!, not if done CORRECTLY. Also, RF Beads are NOT L, they're very lossy,
    very low Q inductors.
    Again, DESIGN the solution. Don't 'throw' parts at the problem and wait
    until it "worked this time."
    #7
  8. mahen
    RobertMacy Guest
    Thank you. Accolade indeed.
    Jan, if you ever want some of the LTspice models and designs for 'pure'
    bypass filtering on uC chips done for n ADC mounted in and about
    Bluetooth, let me know. When I say pure, I mean the bypass looks
    resistive in AND out, all that happens is 'rerouting' the energy to GND.
    That way, you don't get that pesky ringing on the power terminals caused
    by the impedance of the bypass at some spectrum suddenly going up to 10,
    and even 100 ohms reactance! Had to abandon many of the manufacturer's
    recommended bypass components to do it, but gives BETTER performance.
    #8
  9. mahen
    Guest
    Disagree. The resistor between the TVS and I/O pin is better for the
    reason stated (current limiting) and the capacitance of the TVS also
    helps (assuming the R and C don't cause functional problems).
    So do unidirectional TVS diodes. They're a faster than zeners and
    will take a lot more abuse. Low voltage zeners are horrible.
    Of course. The R gets problematic at high currents. ;-)
    , Jan 10, 2014
    #9
  10. mahen
    mahen Guest
    Thanks Jan. may be a dump Q. Series R2 b/w zener and connector already limiting the current into the pin, correct? Why series R1 again?
    mahen, Jan 10, 2014
    #10
  11. They use optos for galvanic isolation, to combat common mode noise, since they handle signals in industrial environments with a lot of ground bounce etc.
    For DM noise, use the tranzorb, resistor, diode, resistor combo
    Cheers
    Klaus
    Klaus Kragelund, Jan 10, 2014
    #11
    1. Advertisements
