13Owen
I have problem with some systems that have up to 6 detectors in series and
reports of false alarms. The difficulty of cause is determining which
detector us the culprit. I am looking for a solution to this problem. One
idea I had was to use a device I saw year ago from C&K system that they
called a Multiplexer that used different value resistor across each contact
the inturn activated the corresponding relay output. My thought was to then
connect each of the outputs to different input of the alarm system to then
determine where the fault may be. I haven't been able to location such a
device or similar or even another solution alltogether. Can anyone help?
